Toploader bridge for American Standard
Discussion in 'Telecaster Discussion Forum' started by KokoTele, Feb 12, 2018.
  1. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    A customer of mine is looking for a replacement bridge for his American Standard Tele (3 mounting screws) and wants a toploader.
    I'm not aware of any, and searching hasn't turned up any. The closest thing I found was a post on the TDPRI from 2010 asking the same question, but getting no leads. Thought I'd ask here just to make sure I had all the bases covered. Anyone know of one that's available?
    nojazzhere likes this.
  2. Ira7
    Ira7 Poster Extraordinaire
    Jan 8, 2008
    Coral Springs, FL
    Aren't there ethical and moral reasons why you shouldn't do it?
  3. boris bubbanov
  4. KokoTele
    The Hipshot one might be a good option. Thanks for the link.
  5. screamin eagle
    screamin eagle Friend of Leo's
    Oct 9, 2008
    S. CA
    What about contacting a company like Armadillo and see if they can drill one of their bridges for top loading to fit an American Standard?
  6. DanDII
    DanDII Tele-Meister
    188
    Nov 2, 2015
    Sinsinnasti
  7. nojazzhere
    nojazzhere Friend of Leo's
    Feb 3, 2017
    Foat Wuth, Texas
    Jim Campilongo and I (;)) both like top-loaders.
  8. KokoTele
  9. Mike Eskimo
    Mike Eskimo Doctor of Teleocity Ad Free Member
    Nov 9, 2008
    Detroit
    Also, don't put it on there, but an early MIM top load rattle hammer (buzz hammer ? Hmmm, I guess both...o_O) bridge will fit right on your body and use the same three bridgeplate mounting holes that are there. You could do it in far less than 5 minutes.
  10. robt57
    robt57 Telefied Ad Free Member
    Feb 29, 2004
    Portland, OR
    I have re-drilled an AS Tele plate for 3 compensated barrel setup and used the 6 original saddle holes for the string thru holes with success years ago.
    LooseJack likes this.
  11. warrent
    warrent Tele-Afflicted Silver Supporter
    Sep 15, 2009
    toronto
  12. boris bubbanov
    I did some work on doing this, but among other things, you've still got the yellow metal chromed bridge plate - which is not so good. I also made aluminum saddles and in retrospect that only made things worse.
  13. KokoTele
    Fortunately, cooler heads have prevailed and he has decided to keep the setup he has. Part of it was that he wanted to keep the upgraded block saddles he has and likes, part of it was that he didn't want to spend real money on it.
    Thanks for the replies, everyone.
  14. reckless meanie
    reckless meanie Tele-Meister
    301
    Jul 24, 2011
    Madras, OR
    You can’t do that. That’s what they do on the cheap ones. If you put a top loader on the guitar will sound like a Squier.;)
  15. KokoTele
    Or a '59 ;-)
  16. reckless meanie
    301
    Jul 24, 2011
    Madras, OR
    I guess it’s ok then as long as it only sounds like the 59’ and not Squier.
  17. Taborcaster
    Taborcaster TDPRI Member
    23
    Sep 11, 2013
    Kalamazoo, MI
  18. geetarLAXjunkie
    geetarLAXjunkie TDPRI Member
    37
    Sep 4, 2017
    KC
